Help Help with upgrade
softail02
Hello All,
Thank you in advance for the answer i will receive.... I upgraded to 4.5.596.mb810 and and am lost with a few issues I am seeing.
1. When I try to Text or email I do not get my contact list where I could just check off the names I want to send to I have to start to type the first letter of the name for it to appear one at a time or hit A and scroll and choice 1 name at a time.
2. When I hold down the button to pasted I use to get a clipboard of previous copied stuff now i get just what I copied last
any help on this will be very much appreciated.
Thank you
Those are both new "features" of the update. The cut/paste one isn't too much of an issue for me since I usually only want to paste what I most recently copied, but the contact one is a much bigger issue - especially if you use contact groups....you can't send multiple emails to the same contact anymore using a group, and in order to send an email to multiple addresses of the same contact - you need to type in each separately - as you described...this "upgraded" functionality could be the worst definition of "UPGRADE" I've ever witnessed. Would take Froyo back with the Email client push issue in a heartbeat over this crap.
both are a real pain the copy and paste was nice cause i would have all my account name in it and just scroll to either the email or account name to past saves a lot of time and headache special with the POS spell correct that changes everything in the world
