help with USB tether...
I have an s3 and the paid for version of Foxfi. I've been successful tethering my no name tablet to my phone using WiFi and Bluetooth.However I cannot figure out how to tether using a USB connection between the two.The tablet has pdanet tablet installed.Unfortunately that program only allows WiFi and Bluetooth connections.Can anyone recommend a program I can use on the tablets end to complete a USB internet connection with my phone? Thanks all!
i do not think you can do it from phone to tablet.....phone to pc, no problem. but android to android will not work.
all of the usb tethering apps out there are for android to pc:
usb tethering search Play Store
not sure if it is possible as you need usb drivers installed on your pc, not sure how you can do it from android to android.
