Help Help with video file
KDroidX
Member
I was wondering what the difference between MPEG-4 and mp4 was. I kept seeing that it was the same thing on websites when i was looking for the answer, yet mp4 videos wont play on my xoom which supports MPEG-4. Any help of what i should do with my mp4 videos?
When I try and play my mp4 file it just skims through it real fast and wont play it normally, but the file plays normal on my computer. I converted the video and made it smaller, it stopped skipping but the audio was completely messed up and just made noises.
I just got off the phone with moto support because im that bored on this sunday. They told me that mp4 was not a supported format for the xoom, and that MPEG4 is supported. Now im confused..
MPEG4 is an audio/video compression standard, that has many "Parts" further specifying the characteristics of the compressed media files
MP4 is a media container format, and it is part of the MPEG4 standard.
So, in order for a media file to be play "natively" in your Android phone, it should comply MPEG4 standard (certain Parts) and be in MP4 container (have mp4 file extension).
That being said, you can also play non-compliant media files using universal players, like Vital Player mentioned above.
I dont understand why the file wont play then, it plays fine on quicktime. Other mp4 files play perfectly fine
Not all mp4 files are equal...
If you want to know the reason, get MediaInfo, then open that file, select Text format and you should see analysis of the video. Copy it here and we can look at the cause of the issue.
By the way, have you tried to play it with VitalPlayer?
Yes on vital player the sound wont work and it lags alot, but i'll do the text thing thanks
General
Complete name : /Users/kanestapler/Movies/The Social Network.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 2.25 GiB
Duration : 2h 0mn
Overall bit rate : 2 671 Kbps
Encoded date : UTC 2010-12-15 05:59:28
Tagged date : UTC 2010-12-15 05:59:28
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=4, N=43
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 0mn
Bit rate mode : Variable
Bit rate : 2 270 Kbps
Maximum bit rate : 17.3 Mbps
Width : 1 280 pixels
Height : 528 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.140
Stream size : 1.91 GiB (85%)
Writing library : x264 core 104 r1677 19df41a
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2270 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Encoded date : UTC 2010-12-14 17:32:27
Tagged date : UTC 2010-12-15 06:07:07
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 2h 0mn
Bit rate : 401 Kbps
Maximum bit rate : 411 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 345 MiB (15%)
Encoded date : UTC 2010-12-15 06:05:19
That's strange, i've tried most file extensions and they have played with no problem.
What programme did you use to rip the movie?
This is the issue:
Basically, the video is very complex encoded, which your phone is unable to decode with its weak hardware. Also, the audio uses very high bitrate (401 Kbps).
Bottom line: your solution is to convert this file. Try using Handbrake with "Universal" preset. Pay attention to audio tab as well. Only after conversion you can play this nicely on your phone.
I got a prob with mp4 as well, my problem is I cant download mp4 formats from the browser, but I can if I use Tubemate.. So my phone supports mp4, but why do I get 'format not supported' when im downloading via my defaul browser? Phone is xperia X8..
