Help Help with Video Tranferring Please
FyrFytr998
The youtube program usually fails. Qik is a disappointment since the option to load to youtube doesn't work. And when I mount the EVO as a disk drive, I can transfer video, but the sound seems to be missing.
Is there a way of transferring my videos from my phone to PC without losing the audio?
You missing a codec on your PC. Do a google search for "MPEG4 codec Windows" - that should get you to a full package.
You can also try http://www.squared5.com
You might consider converting the file to a more modern format such as H.264.
Follow the instructions, because it will entail loading Quicktime and various codec packages - hope that helps.
what version of windows are you running?
