Help Help with wi-fi on Note3
[FONT=&quot]I have a note 3 and can not connect to my wifi at home.. I can connect other places... I have changed my setting so many times on my router Im really not sure what to have it set at (128 bit WEP, 64 bit WEP, WPA2 or whatever else there is) right now my router is set on 128bit WEP and I can not connect at all... Not sure if its a setting on my phone either.... So frustrating.. I have tried to set up a couple of time and got a message that read ( Wireless router security setting WEP is not supported) please please please help[/FONT]
Use WPA2 (Personal, if it has that option) on the router, and pick a new SSID that you've not used before.
Once you have that set, unplug the power from the router and plug it back in, then allow a couple minutes before you try to connect the N3 to it.
