help.. won't go into 4g network??
dubluv11
Hey guys...
I recently rooted my infuse4g and since I did this it won't connect to the 4g network..
I did a search and tried fixing this problem myself by resetting my apn to factory default
I've tried several different things and I can't seem to fix this problem... the phone is either
stuck in 'H' or 3g... it used to constantly be in 4g so hopefully someone can help me out
Did you install a custom rom?
That's besides the point though, H = 4G. They are the same thing, 4G's other name is HSDPA+, abbreviated as H or H+. If your symbol changed you either just flashed a custom rom or new theme, and it just changed some system images.
