Help!!!
aeiou
Last night i downloaded a lot of music to my evo. I noticed some of the album art did not come so i decided to drag and drop them. But for some reason this one particular album art is showing up on the wrong album for multiple albums and not only that the picture is blurry on the wrong albums but fine on the correct one. So i tried to delete the wrong art from the sd card, but for some reason even after i delete the file, it keeps coming back. :confused:
Just a friendly word of advice. You may want to rephrase your OP title to give a brief description of the general problem you are having.
You may get a better and faster and more educated response if you use the title to direct your concern to those who may know. Case in point, I am here to try to assist you but I know nothing about the album art stuff.
Just a friendly word of advice. You may want to rephrase your OP title to give a brief description of the general problem you are having. You may get a better and faster and more educated response if you use the title to direct your concern to those who may know.
Good advice
Here is another poorly named thread about a similar topic from yesterday to check out Aeiou:
http://androidforums.com/htc-evo-4g/122222-fffffuuuuuuuuu.html
You might have to re-tag your music files on your computer and then reload them to the phone to fix the problem? I'm getting ready to put all my music on my new SD card soon, and I hope I don't run into these issues.
After you back up your files
You could try going into Settings-> Applications-> Manage Applications -> Music
Then clear data or clear cache. Maybe the album art gets saved as a thumbnail to a cache so it loads faster?
Good advice
Thanks, and you guys are right, i shouldve made the title more clear. One last thing that i've wondered since i've been on here. What does OP stand for. The other message boards that i post on refer to the creator of a thread as TS for Thread Starter. I've never seen OP before.
You know what? I've never asked that question before:p But I have always assumed that it meant Opening/Original Post... I could be wrong.
Could be original post, if referring to the first post. OR original poster, if referring to the last post by the person starting topic.
The op (original poster) needs to buy music only on his/her pc. Then apply album information through his/her favorite music program.
The op (original post) can be edited to get a better description.
Yeah, It is Original Poster or Original Post; Referring to the person that created the topic.
Side note: Internet acronyms, they drive me crazy!
