for some reson my swype isnt on anymore must of touchd something and now i cant get it back on i see the app but nothing only have the touch input .....can anyone help
check "Language & keyboard" under "settings" and make sure Swype is checked. if that is set right then open messenger or any where you can type, long press in where it says "tap to compose" a window will pop up tap "input method" and tap "swype"
