Root Help!
Ruran
I have no clue what is going on, i rooted my phone a while back and had it lag fixed. I, at some point, had disabled the lagfix and today i went to re-enable it, and when i attempted to start up my phone the boot would come up, but then it would sit at a black screen. I searched around some and the consensus seemed to be that flashed to stock was the fix, so using Odin i did that and all seemed well. But i want to go back to pure, un rooted and lag fixed stock as i'm tired of all the problems, but after the recovery on Odin i can't even install Rom-manager (so i can get Clockwork recovery) as as soon as i attempt to install a app it tells me i don't have enough room. I have 14 gigs free on my SD card and i've yet to install a app, it's a fresh stock. How can i fix this? The application manager is only showing a couple apps that are actually taking up room, my SD card is pretty free - i'm lost. I can't go back to complete stock unless i remove the lagfix, but i can't remove the lagfix unless i can install this app, but the phone says i have no room?
I believe you are having the 0.0 memory problem. That is beyond what I know, buuut. Saps, nitsuj17, or Maz can help you. I don't know mazs full screen name of my head, I'm on my phone and can't get into my friends list. Maz talked me out of jumpin off a roof when my rom flash went bad. Hope I pointed you in the right direction.
I figured some of it out, i found a guide to fix the memory problem, but it involves me using the 1 click root, but whenever i restart my phone it does not save my "android setup" from the previous restart. So when the root goes to restart my phone, the phone goes back into setup mode and disables debug. How can i fix this?
Did you puah clockwork through oden?
puah? Not sure what that means, if it's just a spelling error and "push" was meant no i have not, how would i go about doing that?
Edit: Found it, thanks for the suggestion. Let me play around with this some.
Edit 2: Never mind, it was something else. I'm still stuck with it unable to save my android setups.
Sorry didn't see you had clockwork...when I boot into recovery, I can go right into clockwork from there...I think I will gracefully bow out of this, for I would prolly help you brick your phone. I'm sorry I couldn't be more of a help.
Go into the giude sticky at the begining of all things root. Click on clockwork menu instalation giude. That's how you load clockwork. I don't know if you can load it in the current state of your phone.
Unless i'm mistaken that only gives me the ability to install clockwork from Rom Manager, which i can't install due to the 0 storage.
I think i may have found the solution, i'll put this in here in case anyone else needs it. I'm still reinstalling voodoo so not sure yet.
xda-developers - View Single Post - Please Help - Phone showing 0.00 Storage Space
you dont need all of the 0.0 stuff, just nuking voodoo with adb or adryn's uninstaller
also, id avoid voodoo atm most of us do and we are running either geekniks or jts latest nonvoodoo kernels...its safer, you can backup in cwr successfully, and voodoo beta 5 hasnt been fully implemented yet anyway
You probably were asleep when this gems took place: [20:56] <supercurio> Voodoo5 lagfix is now Eclair compatible
yeah supercurio had been saying it was done, just scrolling through hours of posts to see if jt did it :)
Yeah I saw that last night and was like :eek:. I went to bed when supercurio and birdman were talking about making it all ext4 instead of rfs (some Samsung stuff requires rfs I guess).
On another IRC note, can anyone PM me the link to the recent DJ05 update from IRC, I keep missing when the links are posted there. I would really appreciate it :)
