Root Help
I made a mistake and press factory reset on my phone all the apps that i backedup and froze are back I was rooted but super user is still on here but zroot is gone do I have to reroot and all the apps that I brought can I get them back from the market without repayinh including tibu pro and jus refreeze
Any apps you paid for from the market should be redownloadable, as it should be based on your Gmail/phone account.
If z4root is gone, then you'll probably have to redownload it and reroot.
I haven't had that happen myself so I can't say whether or not you'll have an issue. The only thing I'm sure of is that you should try one of your root-required apps and see if it runs, then you'll have an answer.
