Help help
i have the huawi accend and everytime i turn my phone off, when it comes back on the time is totally off.
Are you using any task killers or battery savers? Also have you rooted or flashed any roms? Are you talking about the widget time or the time in the status bar?
If your using metro. Metro lags when it comes to changing the time. Just wait a few seconds till it shows the correct time.
