Root Help!
Skidoo03
Member
I just flashed this theme [Theme] BlurWiz 2.0 (7/22/11) [EvilFascination3.6] - xda-developers on my fascinate running comrom 2.1 and was told it would work! I wiped cache and dalvik cache then instaled from zip and rebooted. It is in a boot loop right now and I can't get it to stop! It loads up fully then runs the media scanner and just reboots again. I really need a phone and need help please. Also I can't get into recovery, I try and hold the volume up and the power but it just boots up normally. Please any suggestions welcome.
Also once it is booted up it vibrates three times very quick then freezes and then reboots.
And the recovery was a yellow instead of a normal orangeish color and I did a backup before I flashed the theme!​
