Not until you tell us what your problems are... Hello and welcome to Android Forums. The place where you'll most likely get an answer for problems you are having with your Android phone.
Just as iowabowtech said, the best place to seek help would be inside its area of support. Good luck and thanks for joining our community. ツ
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
