S:M930.02 X.FD11 is my baseband version
Build number is GINGERBREAD.EG30
Who's yout service provider? Boost or Sprint, Currently the reason why your having that problem is because when samsung pushed out the "FD11" update way back in june of this year which is the one your running. It had a few bugs that needed to be fixed but they pushed out another one to fix thoses bugs like 2 mounths ago. I can give you a copy of the update and you can follow the instructiosn on how to install it imediately depending on which carrier you have. The OTA for FG11 is still available so you should be able to get it just by going to settings->About Phone-> System Updates and tap to let your phone check for "Update Firmware" and "Update Samsung Software".
