Help HELP
tamjay
HI i really need some help from some with a lot of patience! I am new to this devise i got it on sunday and im really struggeling with it... seems i have already deleted my gallery of picx including the gallery itself... idont care about the pics butcan u plssss help me get back the gallery??
Did you search in the app file in the upper right hand corner of your home screen?
Often, even if you lose an app, it will stay in the standard apps set up with your device.
Hi Tamjay ,
If you do not find the Gallery in the Apps as described above, it may be disabled.Enable by going to:
Ssettings >applications > all applications, then enable the gallery app
