jsphmuckey
Hey peoples, I am currently running Shinjitsu Update 3 & 4
Of course after a few reboots I lost root & had to root w/ pc.. I kno someone else had this problem and I did factory reset, clear cache, dalvik, etc before installing. I think there is an underlying problem with this rom & loosing root. I dunno Lol
Anyways, I love seeing CM10 coming along nicely! Can't wait for a stable release, haven't installed beta cause it looks like there are quite a bit of bugs to be worked out still & I need my sequent working 100percent.
Ok, my question is I'm trying to get video calling to work correctly & with shinjitsu rom I am upside down on both Skype & Tango!! I can't remember if it was this way with stock or not BUT I remember using the cyanoid rom briefly w/ tango and I came up fine (right side up) Anyone else having this problem? Is there a fix?
I don't know why Dizzle would pull the link to the rom? Does anyone have the zip or a backup of Cyanoid? Because that was the rom I had less problems with! I just tried installing the stock rooted rom zip from chris but it aborted right away btw I have cwm touch... for now I am gonna reinstall shinjitsu UNLESS someone has the zip for the original cyanoid? Any help is appreciated
Of course after a few reboots I lost root & had to root w/ pc.. I kno someone else had this problem and I did factory reset, clear cache, dalvik, etc before installing. I think there is an underlying problem with this rom & loosing root. I dunno LolAnyways, I love seeing CM10 coming along nicely! Can't wait for a stable release, haven't installed beta cause it looks like there are quite a bit of bugs to be worked out still & I need my sequent working 100percent.
I was about to install CM10 & gapps for the heck of it & on accident hit the partition sd card buton. Couldn't stop it so I pulled battery out of desperation. Now ALL my stuff is gone! Backups, etc dang, now I gotta download again & install each app one at a time. I think I found a downside to CWM Touch Hahahaha bummer.
I ended up installing CM10 & Gapps, and WOW it is very promising!!!! I love JB soooo much sweet stuff about it I couldn't possibly type it all here hahaha I actually downloaded an update from the goo app & it said it was from 1/29/13! But, wifi did not work
doesn't matter though cause I am not deleting it from my SD
