Root Help!
Sleepingsirens
im trying to run the RUU and it will not work. im unlocked, s-on, and running harmonia and for some reason i cant get it to work. any ideas?
I have one. :) Try locking the bootloader before running the ruu.
fastboot oem lock
It's a requirement when s-on.
If you get another error after locking then you'll need to flash this zip: https://db.tt/JUdxrcC0 via recovery, then attempt ruu again. :)
Also, you're on hboot 1.57 correct?
Ah, bummer. Being s-on, you can't run the ruu after taking that latest ota. :( Because it upgraded your hboot, as part of the security checks, the ruu will not allow you to downgrade while s-on.
Your only option is to become as stock as possible through stock roms or move forward with s-off.
Can I ask what you need the ruu for? Are you stuck in a bootloop?
i was afraid you would say that. i tried s-offing again but my one pin is pretty fried from the dozens of times i s-offed lol, guess im just gonna reinstall recovery and unlock and run the stock rom through it, odex. thanks alot, and i just really messed up and im only having this phone for a month or so until i upgrade. i just need it to work at this point lol, thank you!
hey if your still awake, i was trying to s-off earlier and then i just gave up and tried recovery and unlockeing and when i went to reboot it went into juponbear mode and now its stuck and i cannot s-off whatsoever
