Help!
msd72
I accidentally dragged my text message icon on the main screen into the remove bucket. Can anyone tell me how to restore this? I cannot text anyone without it. Help!!!!!
just got to where you see all of your apps ( the little icon on the lower left hand corner of you screen) find your app and long press on it and it will pop back up on your home screen
OWell, yea. It's actually no big deal. You can do anything you want to, regardless of whether its on the home screen or not. Just tap up the applications tray (the arrow pointing up next to "phone".) and go find the application. To add the icon back to the home screen, just find it in the application tray, and tap and hold down on it. It should pick up shortly after, and the phone make a little vibration. Drag and drop, just like your home computer. Also, try this 'long pess' on actual home screen in any blank space, I think you'll enjoy waht happens.
Android rule #1: If you can't figure something out, try long press - Learn it, live it, love it! :)
