mitchellvii
Hi all,
Anyone who tells you you don't need a screen protector for your EVO because the glass can't scratch is lying to you. Believe me, it can.
But the problem with screen protectors is that it seems almost impossible to get them on just right without bubbles or dust getting under them and making them look nasty.
Well something you may not realize is that even with the protectors that seem like they have adhesive on them, you can rinse it in water first to remove all dust and apply it - it will still stick and it is much easier to squeeze out bubbles with it wet than dry. You can even rub the "adhesive" side with your fingers under the water - it won't hurt it.
Of course, have a rag handy so you don't get any water inside your EVO as you rub the bubbles out.
** Also, to prevent my screen attracting dust before I put the protector on due to static electricity, i lightly rubbed it with alcohol, dried it with a cloth then rubbed the screen with an anti-static cloth. Again, make sure no water gets close to the innards of your EVO for obvious reasons.
