Help hepatic feedback
nebler
Hi, I've just got a new to me HD and can't seem to find how to switch off hepatic feedback when I use the keyboard. I've unchecked the box in keyboard settings. Is it me or is it a glitch of the sense 3 update that's been installed?
Cheers
As well as an option to disable it in KB/Language settings, I think there's an option in the sound settings too. You might want to deactivate that, see if that helps?
You have to restart the phone for the settings to take effect. Not really sure why as it should just work, but unchecking haptic feedback in the keyboard settings then restarting will work
