Hero batterie has lasted ages
natnat
Hi guys, just thought I would share.
I got fed up with my e mail going off every 20 mins and couldn't find a way to alter the rate that the phone picks them up so I switched my internet off using a widget so it's nice and easy to get to.
I now just switch it on when I want to check things like emails or face book.
I swith it on and press refresh. So far my batterie has lasted nearly 3 days and is still showing as half full!
And my email is not going off all the time.
My record was 85 hours :) with no switching off mobile internet and 3 hours of "screen on" though only (stock rom and no root). So what you basicly did is getting a smart phone and made it into a normal phone :)
(btw widget for mobile internet? long press the end call button there should be an option for that and you wont have any more extra service/widget running and you will get maybe some time more)
I guess it depends how necessary it is for you to be connected 24/7 and how often you can charge it.
Everyone will find their own balance of the two.
I got fed up with my e mail going off every 20 mins and couldn't find a way to alter the rate that the phone picks them up .
That is easy. In the HTC email widget hit the button to the left with the three horizontal lines. Then menu>more>settings>Send & Recieve>set download frequency and choose the frequency. If you do not want auto download then choose manual.
