Hi All,
This is my first post... I have a HTC Hero, which I really like, running Cyanogenmod 7 - so yes I rooted it, and have become familiar with ROM management. Before I installed Cyanogenmod 7, my phone started to get into a loop where it would vibrate once and then a second or two later vibrate twice. This would repeat and seem to use almost all memory. In order to get out of this loop, I had to time my shut down (holding the power button down) and quickly tap the shut off button in the pop up screen, and confirm before it started the next vibration cycle. (I learned this the hard way, and spent a lot of time in the ROM management arena, argh) I suspect something is running in the background (not identified by Advance Task Killer) and maybe residing in the (corrupted?) microSD? Once the phone has been shut off and I wait long enough, I can use the phone again... That is until about 15 minutes transpire and the vibration loop starts up again. The long-short is I'm feel it's not the ROM because it showed up after successfully running Cyanogenmod 6 for several months. I will replace the microSD to see if this isolates the problem.
Has anyone else had this problem? TIA
