If there is anything to do with sound ,the phone only vibrates. If you type numbers on phone pad it vibrates and it should have given a sound since it is not in vibration mode.
If you type numbers with the pad, while headphone is plugged in it gives normal sound from headphones. Once you plug the headphones off, it only vibrates again.
when it rings also there is no sound but vibration only..
It seems like it stuck in vibration mode, or no sound mode.
Any advice is appreciated thanks
