hi all
thanks guys, i think i found what i needed which doesn't particularly help my cause lol.
Galaxy Ace GT-S5830i rapidly filling its internal memory.
it was its self! i have 4 apps on there i added which completely clogged up the phone, fb, gun, calculator and page manager, that was it, pretty poor if you ask me, you should be able to have more than 4 apps before the phone clogs up.
we should also be able to move apps to sd card without installing anything that apparently doesn't work anyway.
Wow, four applications caused that... Maybe one of those installed apps was not compatible with the device.
Depending on the device, you might wanna replaced the sd card with a bigger one. If its possible.
Hi runt262 ...
Welcome to the community. :)
Who?
the apps don't install to the sd card they install to the phone memory and the sd is a 2Gig
