hi i just begain learning java and i need advice
hi im used to vb6 but the future seems to be in java so here i am.
what im wanting to do make some of the games i made in vb6 into android apps if possible .
should i start off makeing the games in java for windows first or just studying beginning android games ,,because theres alot of stuff i need to do,that the books dont tell.
thanks all
thanks all
Welcome to the AndroidForums, flyhigh427.
You've made a great insight there: yes, there's ton's that you need to know that aren't covered in the programming books. You'll find lots of places to start in these threads:
http://androidforums.com/application-development/663630-application-development-developer-101-stickies-list.html
this one is especially good:
http://androidforums.com/application-development/377722-welcome-start-here-faqs-tips-learning-resources-tutorials-helpful-threads.html
Finding resources and tutorials is a great place to start, too. You'll find real-world examples that will help cement what you're trying to learn and absorb. Just take your time--there's a lot out there and it will take a bit of time.
Well Thank You
My typing is bad ,yes
Many Thanks to you ,sir
You typing is just fine, flyhigh427--we don't care one whit how folks type here as long as they are polite and respectful to each other--which you certainly are.
Please let us know if we can help you find anything around here. We're very pleased you signed-up with us here at AF.
Cheers!
