Help Hi. I need help with my Motorola Triumph
aptwang44
How do I transfer videos taken with my Motorola Triumph to my computer? I can't send it since the file is too large.
How long can I take videos for (and send) if the quality is the lowest? Highest?
Welcome to Android Forums, aptwang.
I've moved your question to the Motorola Triumph forum for you. :)
First of all, you need to have the Motorola drivers installed on your computer. They are available for Windows and Mac here:
https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/88481
Now it's a matter of making the connection via USB cable from your device to your computer. Once you do that, drag down the status/notification bar and tap the "USB Connected" notification.
Turn on USB Storage by tapping that item, then just use your computer's file interface to view and transfer files of all types. ;)
I don't even think you need the drivers? Just plug the USB cable in to a PC and select "USB connected" on the phone and turn USB on. Then it will show up as a USB drive. Then you have to find the video files on the USB drive (phone)
