hi plzz help in my new backflip
bhuvantej
hi evryone
i am in trouble plzzz help me
i will give rs 2000 who helps me
this is my flash error while flashing cutom rom using rsd lite 6 plzz help me guys
my pc is windows 8 64 bit
and i am from india
2013/06/09 21:41:28 | 0 | ERROR: Phone[0000]: Error sending JUMP command Device API Error: 0xE0030040 Address: 0xB00000 Command: JUMP ->(611)RDLOp
2013/06/09 21:41:28 | 0 | ERROR: Phone[0000]: Error jumping to RAM Downloader ->(329)RDLOp
2013/06/09 21:41:28 | 0 | ERROR: Phone[0000]: Flash failed. ->(1195)PST_FP_FlashThread
2013/06/09 21:41:28 | 0 | ERROR: Flash failure: Phone[0000]: Error sending JUMP command Device API Error: 0xE0030040 Address: 0xB00000 Command: JUMP (Error Code: e0030040),
Detailed Error Details: Direction of the Error=2000, Command Value=500000, Code Group Number=No Codegroup ->(625)FlashHdlr
2013/06/09 21:41:30 | -- | ERROR: Error getting subscriber unit information. ->(1507)PST_FP_FlashThread
2013/06/09 21:41:30 | -- | ERROR: RQHW Response(Error):
Hi there and welcome to the site :hello:
Are you sure you have the proper drivers installed? Also, be a bit more specific as to the actual name of the file you're trying to flash. It's possible it's not the correct one or it got corrupted in the download.
