Hidden menu admire
jaimecool
Hey guy I just wanted to share that I have found and know how to enable the samsung admires secret menu it does have one my problem is accesing it which I have yet to figure out to enable it I use launcher pro and hold on an open space and go to shortcut select activity find com.samsunghiddenmenu open and scroll down to find hiddenmenu tap and once the shortcut is created open it and hit enable once I find how to acces the menu itself I will post how and if you find how to access it plz tell me thanks
someones beat you to this it, there are about 2 or 3 threads about the hidden menu and you can even google it to find all the codes for it. you access it by using the dial pad, an example is ##33284# which if for the debug menu
http://androidforums.com/samsung-admire/486147-samsung-admire-hidden-menu.html
got to post #6
http://twilightwap.com/mobile/secrets.asp?phone=samsung
some of these work too but I wpuldnt mess with them cause these can mess up the phone, they are meant to be used by someone from Metro that knows the actual purpose of these codes. Best thing to just enable the hidden menu cause the people over at Metro dont seem to know that it isnt enabled to begin with. before you know it theyll begin to tell you to put in a code and since the menu isnt enabled you couldnt be able to do it ;)
