After recieving a new router from my ISP a couple of weeks ago I've had to configure the SSID as hidden to allow my laptop to connect wirelessly to it. The laptop runs Vista and if I leave the SSID un-hidden Vista thinks it is a public network and no matter what I try it restricts me to local access only. Once the SSID is hidden the laptop connects no problem.
Once the SSID is hidden my Desire cannot connect to my network or even see it. So by fixing the laptop problem I create a problem with connecting the Desire to my WiFi network,
Has anyone else experienced a similar problem or found a workaround or solution for it?
. It says below the network "not in range, remembered" even though I'm sitting right beside the router so there is no issue with signal strength.
