Help Hide app on S6 Edge
Dear Support,
I cant find dissable bottom on setting application manager.
Only Force stop and uninstall ?
Please advice, how to hide app on S6 EDGE ?
Waiting for your advice...
Br,
Remond
We're not a support service and aren't affiliated with Google or Samsung - we're a group of peer users helping each other with what we can.
Not all apps can be disabled.
You can try a different launcher from the Play Store and have better control over the apps you see. But they'll remain in the application manager.
If it can be uninstalled can you not just do that if you don't want it?
As Early says, other launchers can give you more options for hiding apps, but only uninstalling removes it from the app manager.
System app (bloat), in the top right of your app drawer, tap edit and select the app you want to hide that'll disable it.
However if it's a user app that you want to hide, you'll need to download a secondary launcher since we can't natively hide user apps on the touch wiz launcher
