I am wondering why the current usage with the Triumph is so high. No wonder battery drains so quickly. I used to have the same problem with an HTC HD2 running android and it was fixed with multiple rom updates created by dev in xda.
Eventually with the right kernel and rom the standby/sleep current usage was 2-7mA. With the Triumph the standby/sleep current usage is around 100-300mA.
With the screen on current usage can be as high as 500mA.
https://market.android.com/details?id=com.manor.currentwidget&hl=en
This is the widget from android market.
Try it and let me know what you find. Most likely the battery consumption can be improved by a kernel / rom combination.
I am using MIUI at the moment. Will post the current usage after running for 1-2 days.
