Root Hitting "menu" to dismiss lockscreen... (xtr)
cmotion
I just flashed xtr4.whatever and I forget where the option is where you can decide if you want the menu button to dismiss the lockscreen. It seems to be on by default and I'd like tip turn it off. Checked in settings, spare parts, all to no avail. Am I imagining this option or can someone point me in the right direction?
I haven't tried this ROM yet, but if its based off of CyanogenMod, you "may" have a CyanogenMod settings in the settings menu. If so, it would be(going based off of Kaos Froyo):
Settings > CyanogenMod Settings > Input Settings
Scroll to the bottom, and there should be a "Menu unlock" checkbox.
I hope this helps, if it doesn't.. then :confused:
xtrROM is based off of the stock HTC Eris frameworks - it's essentially Sense without the launcher. I believe that unlock with the press of the menu softkey is a feature of stock HTC Sense and cannot be disabled. I have never used the app Spare Parts - does that allow this feature to be disabled, does anybody know?
I haven't tried this ROM yet, but if its based off of CyanogenMod, you "may" have a CyanogenMod settings in the settings menu. If so, it would be(going based off of Kaos Froyo):...
It is not a CyanogenMod, but thanks for the heads up there!
Also Frisco, I'm not seeing it in Spare Parts either... I thought I remembered it being there but when I checked I couldn't find it :confused:
