Root Hoe to solve sign in issues with Android Market
Did this work for you?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • This bricked my phone
    Votes: 0 0.0%
  • I'm going to piss in your Cherrios
    Votes: 2 100.0%
  • Total voters
    2
lowki
I have learned a lot from this forum, but with this one issue I had not found any answers so I thought I would contribute back to all the people who helped me. If you have recently rooted your phone or flashed a new ROM only to find that now you can not sign into Android Market don't worry there is a simple way to fix this. Most ppl will tell you to do a soft (turning the phone off with the power button) or a hard (remove the battery) reset will solve the problem. It will not. I think this is a great place to start with a lot of problems, so don't discount it, but I also think this is the answer ppl give when they don't know what to do. You need to go into settings - Applications -Manage Applications - tab at the top that says "All" - look for "Google Service Framework - click on it - a window will appear will a few options - click "Force Close." this should get you back into the android market. There is some sort of link between Google Talk and the Android market. If you are having this issue then you might also be getting a warning that says "Failure to sign into Google Talk." If this does not work, contact me and I can give you few ideas to work with, but this is what worked for me. Thank you shabby, Hroak ( sorry if I spelled it wrong), CWM, and all the ppl on this forum.
Fixed mine after trying for hours and going through all of the suggestions that I could find on here, and none of the listed above worked for me.
I finally fixed it myself by uninstalling updates for Market and then let it re-update and it worked fine after that.
I didn't need a hoe to help me either :)
If you just flashed a ROM the Google authentication error could be that the cache needs to be converted back, you can do this by doing a factory rest in CWM
