Holster/Shell Combo
jmill75
Member
Quick question, Ive had the holster shell combo for all of my phones, just received mine for the Bionic. All the previous ones the phone slid out pretty easy, this one is almost impossible to get the phone over the lip without using 2 hands...is everyone's like this or is mine defective....just curious
Try pushing up from the bottom. It comes out easy if you do it that way
I returned mine the second day. It was frustratingly hard to remove the phone from the holster, and I missed a couple of calls. I am waiting for Seidio to come out with their spring clip holster for the Bionic. I had one onmy original Droid and it was great.
Pushing from the bottom does work, but that is a bit excessive. Still takes 2 hands and pushing hard. My other phones Tbolt,X,Charge all slide out smooth. I love the protection of the HSC though.
Good grief...y'all sound like a couple of women *itching about your new pair of shoes not fitting just right. Get over it, and take comfort in the fact that if you drop your phone it wont come flying out of the holster and skip across the pavement.
U r doing it wrong if it takes two hands. Use one hand and press up from the bottom. Geez I already explained this.
OK, enough of the testosterone and the jibing at users.
FWIW - I've learned to use just my middle and index fingers to press upward from the bottom and it comes right out. If yours doesn't come out easily, I'd exchange it for another one - it won't let the phone fly out, but it isn't a PITA to get out either.
