Home Button Jacked After OTA
cb85215
After installing OTA this morning my Home button has lost most function.
Have to use "Return" (arrow) button repeatedly to back out to home screen.
Also lost function of Home button bringing up 7 screen selection when pressed on main home screen.
:mad:
....and yes, I have tried rebooting.
Yeah, I'm positive it was working "as usual" last night. Definitely jacked after the OTA....I'll try a battery pull and see if it makes any diff.
Mine works fine after the upgrade.
The only thing I had an issue with was with myLock Auto Unlock. I had decided not to use it yesterday since it also bypassed the pattern page, but after the upgrade it re-enabled. Looks like it no longer completely works, you still have to swipe down, and it bypasses the pattern page. Like I said, I don't use it anyway, but others might.
