Psiloveyoum0re
Forgive me if this has already been posted.
My home key is kinda sticking. I don't know if something has been spilled on it or what. It just doesn't click. It's a little hard to press. Any suggestions on what I could do?
); rubbing alcohol that is, and swab it around with a cotton swab or "alcohol wipe" a lot as it is harmless to electrical components and plastics, etc of a device. First turn the device off so that you can work the key with your finger while swabbing.
worked like a charm
