Help Home..Navigator Problem
JameyK
Member
Something new today...
When I use my Advanced Task Killer, it brings up the Task Killer and Navigator.
If I have kill Navigator and then press "Home", it brings back "Kill selected apps" and there is Navigator again. Press "Home" again and there it is again.
I can use the back arrow to get back to my home page but it pushing "Home" starts this all over again.
Help.
Such is the fate of using a task killing app. One often kill important apps or processes and then funky behavior begins to happen.
I would quit using a task killer unless you happen to have a rogue app that is causing issues once in a while. However, in that case you would be better off in just uninstalling that app.
