Root Home screen is black after hard reset.... HELP!
HELP! I recently rooted my phone and deleted a few stock apps, all of which were on that list of apps that were okay to remove. I just did a hard rest and now when the phone turns on, it just sits at a black home screen. The only thing i can do it hold down search and search the web, seems like from deleting some widgets it messed things up. Any way i can install a new from or something like that?
Did you ever create a backup? If so boot into recovery and apply that backup. I renamed a lot of my apps. In my opinion renaming .apk to .bak is better incase you need to reinstall them for whatever reason.
