I recently over-flashed CELB 4.3 on top of CELB 4.1, and was using the phone in my usual manner, when I noticed that my "Home" softkey was no longer working - either long-press or tap. Didn't matter where I was - even on an ADW home screen, neither "tap" nor "long-press" did anything.
Here's where things got weird. I assumed it was a problem with CELB 4.3, so I rolled back to a recent CELB 4.1 nandroid backup - the same one I had overflashed with 4.3.
Same deal; no "Home" button. Panic!
I replaced my screen protector - because it was lifting right near the Home softkey (it was 15 months old, so time to replace anyway). No joy though - no Home softkey. More panic - do I have bad hardware?
Then I rolled back to an unconfigured July 2010 OTA ROM; much to my relief, the Home softkey was now working. Yeah!
I had several CELB 4.1 nand backups over the last two months, so I rolled back to a CELB 4.1 backup that was about one week earlier than my latest. Yay, the Home key worked there, too! So, clearly something happened - either something I did or an app update - that had bolluxed up the Home softkey.
A number of apps in the market had updated within the past couple of weeks, so I slowly added back in market updates for apps a couple at a time (into the restored backup), to see if maybe one of the apps was causing the trouble. Even rebooted a couple times too. But, the Home softkey is still working, after updating everything.
So, the only wildcard left is *me*. I suppose I could have easily fat-fingered a setting or something without noticing it... and I note that the ADW Launcher "General Behavior" menu has a toggle that I am unfamiliar with:
Sense previews (enabled)
Anyway, my problem is fixed - but I'm wondering if anybody else has experienced this same problem? Could be just a data-dependent bug in ADW, and once it happened, it got carried forward into the new ROM when I overflashed.
eu1
eu1
