Help Home switcher - Launcher Pro
gocardinals
Haven't used Launcher Pro in awhile, but wanted to try it again tonight. When I went to Home Switcher to make LPP my default, it keeps reverting back to Sense whenever I hit the home button. In other words, I can't get it to stay on LPP. Any suggestions?
I had this exact problem last night go into Menu>settings>Applications>Manage Applications> Hit all tab on top find HTC Sense click it; go down to clear defaults and there you go ^o^
I would reinstall home switcher. And yes, it does work with Froyo. In fact, I just did it on my phone just to make sure.
However, just in case something got bugged in your defaults, I would go in and clear the defaults on both HTC Sense and Launcher Pro. Then when you hit the home button and it asks you to set a default, pick LP.
Reinstalling Home Switcher and resetting the defaults didn't work. Home Switcher still not working.
If you reset the defaults on both Sense and Launcher Pro, you shouldn't even need to use Home Switcher.
What SHOULD happen is this... reset the defaults in both launchers. Then hit the home button. You should then get a popup asking which program you want to open with an option to set it as a default.
If you don't get this, clear the defaults again and then try rebooting the phone (turning off then back on) and that should clear it.
