Home Wifi problems or phone wifi setting problems??
lcfz86
my phone cant online after turn on the wifi at my home... but the wifi look ok... & others place was no problem using the wifi...
isnt my phone wifi setting problems or my home router setting problems... ><
Hey buddy, i'm back, more info please, like what kind of security do you have on your router, (i.e. wep/wpa/etc., is the ssid broadcast, and so on) also, what type of router (802.11 a/b/g/n) do you have, and anything else you think might help...
I'm having the same problem too :( I really need some help. My router's security type is WEP. I don't know how to check what type of router I have. I couldn't connect to my home Wi-Fi. It says 'Limited connectivity'. It's really annoying and frustrating. I tried many ways but I still couldn't fix it. I really need some help :(
WEP sucks. Use WPA.
Check your router, it normally atleast has the company logo somewhere on it, and it should have a sticker with a model number on it.
email/gtalk me (it's on the about me section of the profile) if you run into any problems. I have my phone on me at most times, but please, for my sake, try to keep it between 10am - 11 pm Central Standard Time.
