Homerun Battle 3D
I've heard so many great things and want this game so badly though I can't find it anywhere. When I was on 1.5, it wasn't in the market. Now I'm on 2.1 (2nd leak), and it's not there either. I found the pname link and search results came up empty. I then downloaded the .apk and manually installed it, and it force closes as soon as it starts. Frustrated and looking for help/answers, any help would be appreciated. Thanks.
that game was built for phones with larger screens so you will not be able to use it until they update it so that it will fit on the small eris screen
It will work fine. Im running it. The trick is to launch the app then let it sit for atleast 5 minutes before clicking start.
Try that it works for me.
I'll try that, thanks. Any reason as to why it's not in the Market for 1.5 or for 2.1? Same with At Bat '10 and I'm sure other programs. Why do some show up and others don't for some?
Try a little bit longer. Also if you purchased and have any version higher than 1.23 it will not work very well, (updates were designed for higher end devices)
Socal shoot me a PM.
The apps that are "copy protected" don't show up in the leaked store for 2.1 and the game wasn't desinged for 1.5 so thats why it wont show for 1.5.
Let me know.
Since this game is back in the market i downloaded it but it force closes a bunch when im starting it and its a little bit choppy and laggy when it actually does work. I still like it though. Anyways, can someone that has overclocked their eris see if this game works better with the faster speeds? There is a free version in the market. It would be greatly appreciated and make me want root even more.
This is getting annoying. I can only play the game when i have my music player playing also. Really sucks cause it drains my battery like 20 % in 10 minutes. but at least i can play.
