Help homescreen lag when using any sort of static wallpaper. please try it**
vinnyt225
Member
i recently discovered this regarding the use of a live wallpaper. im running stock gb with the most recent update. i tried to use the live wallpaper C-ThruFone in the market. Apparently it does not work on gb 2.3 but when u go to use it, it turns the background to a blank black background and one of the things i notice is that it much more fluid when moving across different homescreens. then when changing to a regular static wallpaper such as the ones htc has provided, the scrolling of homescreens seem less fluid.
can anyone try this out and see if im right? thanks
