Homescreen moved
essexgooner
Hi all, I downloaded gingerbread upgrade last night and today I noticed my homescreen has changed.
I had it set for the 4th screen on the phone but now for some reason it has changed to the 8th screen!!!
Is there a way I can change back without literally moving everything one by one?
Using Go launcher by the way.
Yeah just press the menu button, then clic edit, then find the screen you want for home, then click the yellow pin icon & that will choose what screen is your home screen! & thats it.... hope this helps
Or just double click on the home button and then rearrange the thumbnail home screens as you want. With a long press on a thumbnail home screen you can it pull arround at the display.
Harry
