Honeycomb 3.1 upgrade
My A500 came delivered with release 3.01 and whenever I check for the 3.1 upgrade it says system up to date.
My question is this. How does Acer determine which tablets to push the new code too ??
Anybody know ??
Thank you
I wish I knew.
1st prompted me to update like 5 minutes after I turned it on
2nd one never got the update notice, although I didn't manually check for it in the 4hrs or so that I had it
3rd one also never got the update notice or maybe I did but since the screen wouldn't stay on I wouldn't have noticed.
4th one I got the update prompted maybe after about 6 hours of using it.
