Root honeycomb for launcher pro/ stuck in continuous force close loop
double1
Installed this honeycomb for launcher pro, tried the calendar app and now i'm stuck in forced loop. I can do anything on the phone now :(
You can do this one of two ways
one: reboot into recovery and clear user data (don't need to be root)
two: (need to be root) type into adb
Code:
adb shell
su
mount -o remount,rw -t yaffs2 /dev/mtd/mtdblock3 /system
cd /data/app
ls
rm whatever.apk
reboot
replace whatever.apk with the name of the app you installed. after you type ls in adb it will tell you the names of all apps you installed. So look and find the right one.
if you use the first method to get all your contacts back just sign into google again. Make sure in accounts and sync that you have contacts checked
