CdTDroiD
Samuel2706 & CdTDroiD
Presents
Features:
- Android 2.3.3 (Gingerbread) - OFFICIAL HTC RUU 2.50.405.2 (RELEASED 3.7.11)
- Honeycomb themed LATER UPDATE!
- Lee kernel: 3.2.0
[*]Built with the latest GCC 4.5.2 tool-chain (2nd May 2011) 100% clean build
[*]Available CPU Governors - Interactive, Smartass, SmartAss2, Conservative, Powersave, Performance & Userspace
[*]SmoothAss CPU governor as default (245-1036MHz)
[*]Max speed - screen off 499MHz
[*]Max O/C 1.8GHz ("Nutter mode")
[*]LeeDrOiD Optimal CPU table & VDD Levels
[*]Brain **** CPU Scheduler as default (CFS optional)
[*]VR I/O Scheduler as default (Deadline, Noop, SIO, BFQ V2.1 & CFQ Optional)
[*]OpenVPN - CIFS - UTF8 - - EXT3 - EXT4 - JDB2
[*]Audio boosts - 10% all outputs, 15% External speaker
[*]WiFi Driver improvements & greater range - Rooted and Superuser added
- Unsecured boot.img
- Various tweaks for speed improvements
- Battery calibration script (Thanks to the dev seo)
- Multilingual ROM as all WWE are
- Zipaligned @ system/app and data/app on boot
- Fully de-odexed
- init.d scripts (BusyBox run-parts) support
- NANO text editor & sysro/sysrw commands support
- EXT 4 VERSION
- EXT 3 VERSION - for you non adventurous types (Coming soon)
- Improved battery life, imagine a newer car vs the older car.. (Older car being STOCK ROM)
- Includes support for customization and flash 2.50 mods ONLY over this release
- Arabic and hebrew support find them in the addons section!
Flashing Instructions:
(unless stated otherwise)
1. Boot into recovery
2. Backup
3. Flash Honeysense HD EXT4 Full wipe
4. Flash Honeysense HD 7.1.0
5. Boot up and setup phone
6. Eat a donut of some variety - VERY IMPORTANT
DONE
Change Log:
HONEYSENSEHD v7.2.0
FULL WIPE NEEDED
+Fixed speed issue (critical update)
+Added new theme (hasn't been updated since may)
+Added full screen lockscreen
+Fixed the systemui white on white problems
+Fixed the boot animation to correct one
+Updated some of the icons
+Same base, built from scratch
+Reverted to stock icons
-Addons will be coming soon for other icon packs
+Fixed the line in the app drawer so it's not visible
+Fixed to sense 3.0 weather sounds fully working
+Fixed the lockscreen apps being square
+Fixed the compression error which caused the google app/google + app to force close
+Added a few stability changes within the ROM
+Fixed the list sorting problem can now sort by a-z and
+Fixed the black on black problem and the incomprehensible text
+Fixed the slow speed issue
+Reverted back to the much loved 7.0 boot animation
+Fixed the loss of view settings when rebooting
+Fixed numerous force closes within applications from market place due to compression errors
+Fixed the Extended settings on status bar, task manager is back and all are in correct order
+Lockscreen is now 3.0 on during calls - thanks to seo for spending an hour helping me with this.
+Weather fixed for good! Sounds now enabled
+Sense 3.0 with 5x5 app drawer(done by myself)
+Various speed tweaks and added some init.d scripts
+Updated the entire ROM
Credits to:
Adamholden85 For help with swype and the theme
Killersloth for the swype release and his Undervolt script, cheers pal
Seo for sense 3.0 for 2.1 and for help
Leedroid for the kernel + inspire 4g patch
Mike1986 for EXT4 Help and O/C Daemon help
Krzysiec for help and links
Cappy & Co for bringing half of this to us
Leith51 for inspiration and the help
Major thanks to he_stheone64 for all the help and the theme.
andyharney for the ftp and helping me with CM7 theme
Code:
[CENTER]If you like my work:
Hit the thanks button
Rate this Thread or
Donate Me a Beer by clicking the donate to me (i like beer)[/CENTER]
Donaters will be listed here
ARNT VIGGO GAUSVIK $20
Seany Biker $10 $10 $10 $10 -TOP DONATER
Dhani Debavalya $5
amit asdhir $10
Fernando de los R
