Help hooking phone to computer
canrunin
when i do this,my computer opens up my 2 windows,just wondering if i am looking at the sdcard and the internal memory.my droid eris only opened up 1 window when i hooked to computer.if this is the case,is there a way to tell which is the sdcard and which is the internal memory? thanks
Yes, that is correct. Once is the SD card and one is internal memory. You can actually rename those mounts whatever you want to make it easier to know which is which and it will save the names when you dismount.
As far as your Eris goes, make sure in you settings under Connect to PC that your default connection type is "disk drive" - otherwise, you will ONLY see the SD card mounted.
Initially go by drive size so you know which is which.
