Help Horizontal lines on screen?
jzl2112
Just took a picture about an hour ago, no problems. Locked it and put it in my pocket. Then I unlocked and the camera app was still up. I closed the app and noticed there's horizontal lines and a sense of flickering anywhere I look and the startup screen has crazy colors around it. Already reset with no luck... Any ideas?
Your phone got to hot and a component inside the device is shorting out. You may receive a blank screen after a while. You need need to do a little research on your devices resistors to determine which one is not producing enough power and replace it.
Not a technical enough person to do any hardware work, just hoped it was only a software issue. Oh well, was thinking of getting something new anyway. Thanks for the quick reply.
