dierna
I have a Galaxy S4 from Telus (Canadian carrier). For the past few months, my battery life has been absolutely terrible. I'm not rooted, running Android 4.4.2
What I've tried: Factory reset, keeping bluetooth and GPS off, wifi off unless I'm home. I ran the phone without any apps installed for two days to see if there was a rogue app causing my battery drain.
I was home today, had a signal, was on wifi, and hardly used my phone. This is a screenshot from GSAM Battery monitor:
As you can see, the system is using my battery, not the apps. I've never had this problem before. My phone is warm or hot most of the time, even sitting in my pocket or on the table. I have checked both of my batteries, and neither of them seems to be bad (they're both flat, no bulging). Both batteries give me the same drain problem, so I don't think it is the battery.
I'll post the data from GSAM in a moment.
